Flint 4.1 r2 - goodcloud
Is goodcloud plugin fixed in this version ? I can’t access remotely via app
Which version of the App are you using? It should work on version 1.4.
What are the problems that occur? Is the device always offline? Or does it show online but access is reported as an error?
App 1.4 (121)
Keep showing device timeout
Looks like my parent router adblocker. Any goodcloud address I can put in allow list?
There are the domain lists of GoodCloud that you cloud put in your allow list.
www.goodcloud.xyz
jp.goodcloud.xyz
eu.goodcloud.xyz
us.goodcloud.xyz
gslb-jp.goodcloud.xyz
gslb-eu.goodcloud.xyz
gslb-us.goodcloud.xyz
Ok thanks updated allow list, seem to be working, will monitor.
Goodcloud via browser is still better than goodcloud via app, app keep showing timeout
