Hi everyone,
I’m wondering if anyone else with a Flint 4 and PS5 Pro has experienced similar problems.
I’m having a really frustrating issue where the PS5 Pro constantly struggles to maintain a stable Wi-Fi connection when gaming. I’m getting timeouts and connection drops, to the point where the router is basically unusable for me with the PS5.
I’ve tried quite a lot of troubleshooting already:
• Disabled MLO
• Tried 5 GHz and 6 GHz separately
• Dropped the 320 MHz bandwidth down to 160 MHz
• Also tried 80 MHz
• Set up port forwarding
• Given the PS5 a static IP
• Installed Universal UPnP through LuCI
• Tried the original firmware
• Tried the second firmware release
• Tried the beta firmware
• Tried different NAT configurations, including Full Core NAT
Nothing seems to make any real difference.
if I switch back to my old Wi-Fi 6 router, the PS5 Pro works absolutely fine in exactly the same location and setup. No timeouts, no instability and no problems playing online.
So I’m wondering whether this is a known Flint 4/PS5 Pro compatibility issue, or whether there’s a particular Wi-Fi setting I’m missing.
Has anyone else experienced this with a PS5 Pro? If you have one working reliably with the Flint 4, I’d really appreciate knowing what firmware and Wi-Fi settings you’re using.
At this point I’ve tried so many combinations that I’m running out of things to test!
