Hello.
Just upgraded to the new Flint router and so far I like it, but there are a few things that I have noted below:
The GL.Inet app does not show WPA3 encryption option
The Gl.Inet app and Web interface show limited 5GHz channels, which I assume has to do with DFS on the other channels
The Luci interface does not show WPA encryption options or AX mode selection
Quectel EP06 in USB enclosure works only over /dev/tty/USB3; cannot use cdc-wdm0:
Thu Nov 18 17:30:43 2021 daemon.notice netifd: Interface ‘modem_1_1’ is setting up now
Thu Nov 18 17:30:43 2021 daemon.notice netifd: modem_1_1 (15299): ./qmi.sh: eval: line 1: can’t create /sys/class/net/wwan0/qmi/raw_ip: nonexistent directory
Thu Nov 18 17:30:43 2021 daemon.notice netifd: modem_1_1 (15299): cat: can’t open ‘/tmp/modem.xhci-hcd.0.auto/signal’: No such file or directory
Thu Nov 18 17:30:43 2021 daemon.notice netifd: modem_1_1 (15299): “No effect”
Thu Nov 18 17:30:44 2021 daemon.notice netifd: modem_1_1 (15299): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/wwan0/qmi/raw_ip
Thu Nov 18 17:30:44 2021 daemon.notice netifd: modem_1_1 (15433): Stopping network modem_1_1
Thu Nov 18 17:30:44 2021 daemon.notice netifd: modem_1_1 (15433): Command failed: Permission denied
Quectel EP06 connected over /dev/tty/USB3 cannot pass data. It shows connected and has an IP address, but data does not work. I know this modem/carier combo works cause I was using with an AP1300.
Tried Sierra Wireless MC7455, but it does not work at all. It shows up in the syslog when plugged in, but never in the GL.Inet web page. I have read all over that this modem needs MBIM mode to work in OpenWRT, but then I see that the Sierra QMI packages are installed, so I am not sure.
As with AP1300, IOT devices with ESP8266 cannot connect. I work around this by using an AR150 in AP mode
