Flint AX1800 - v4.4.5
Do we need to downgrade the version : “v4.4.5”
i dont see it as available on the download list and seeing some issues reported here in the forums.
admins → let me know please.
You don’t need to update 4.4.5. Or if you want to update 4.4.5, I suggest you to not keep the settings,you need to reconfigure the router after update,then the router will work fine.
ok - i already updated two days ago, i didn’t encounter any issue so far with the stuff i use.
These issues are all about the original settings before update. If you didn’t set a lot of configurations. It will work fine with 4.4.5.
