Flint - clear out some disk space?
I'm getting the following error because my flint disk space is full.
I was using Hagezi ultiimate blocklist now I've dialed it back to Hagezi Multi Pro.
There are obviously some files sticking around that I think I can delete.
Can you guys recommend some options for clearing out disk space please?
Thanks
Error: control/filtering/set_url | writing rule line: write /etc/AdGuardHome/data/filters/.1731615881.txt3392322746394186292: no space left on device | 400
Delete the AdGuardHome filters.
If this does not work, stop AdGuardHome, remove the whole config, and restart it.
(This will cause data loss in AdGuardHome of course)
Bit late to respond, thanks admon - deleting adguard home files worked.
