I stay on GL-iNet beta 4.8.2. It run smooth, and also because i cannot find âEncrypted DNS - Oblivious DNS over HTTPSâ setting in Luci .
By the way, where is the bluetooth chip and antenna used for in the flint/AX-1800 ?
I donât see bluetooth tethering at multiwan settings, assuming cellular goes by usb cable?
I also donât see any bluez related packages in Luci software at GL-iNet firmware (we can make the router as a audioplayer for play usb storage to bluetooth speaker, if we want ).
Well I sure hope there will be an update soon for the Flint 2 router. It has trouble maintaining the SQM setup which parameters are correct, but it either doesnât shape the traffic, allowing for variations in latency or it does for a while, and then will randomly stop working until I go in and fix it either with a manual restart or full reboot.
Very disappointing as this is one of the reasons I got this router in the first place. Tinkering with upnp when installed through luci is also unreliable as it doesnât seem to open the ports necessary for instance an online game.
A more straight forward way of updating the built in AdGuard UI without having to use a script for those not a tech savvy with cmd lines and linux, etc. Not sure if this is possible, but would be awesome.
And security updates like other manufacturers out there do for there network devices? Just throwing this out there, wanting to see the device to continue to get support and love since I recently got it about a couple months ago.
The last stable one I see is from 9/1 of last month which I'm currently on. I suppose you're referring to the beta on 9/25 4.8.3.
Don't want to risk it with the snapshot variants as stability is very important for my network.
Thank you, I hope to see continued support for this model. Curious though, what do the snapshot versions have included that different on the daily? Just daily internal tweaks and changes? I always look for release notes
Just reserved for 2B customization version.
There is actually no SMD Bluetooth chip in 2C standard version.
It is actually not used for network sharing but originally planned for IoT.
I updated and made a separate post... having some serious issues with getting back online and running. Can't install packages like luci-SQM, can't update current packages due to incompatibility.. This thing is a mess...
Edit: Rolled back to the latest stable again. Seems to have restored functionality.. going to continue setting up from scratch.
Yesterday i flashed the ax-1800/Flint1 to openwrt-25.12.0-rc1-qualcommax-ipq60xx-glinet_gl-ax1800-squashfs-sysupgrade.bin within Luci on original 4.8.3. gl-inet firmware.
But the device was not working properly, not accessible with http or ssh over lan1 port. (192.168.1.1) .
So flashed back to original GL-Inet 4.8.3 beta with older openwrt. (Uboot is a nice invention)
Iâm on openwrt 25.12 rc1 now with my Flint1 (Ax-1800).
It works perfect. What i did wrong is, flashing it in GL.inet firmware with bin file from 25.12.
You need to use Uboot (unbrick option) and flash the UBI file of 25.12 from openwrt firmware selector.
Then you have a basic openwrt with Luci. (default it uses 192.168.1.1 as lan ip).
NOW DONâT DO THIS IF YOU NOT EXPERIENCED WITH openwrt/luci.
Because their is indeed a learning curve when doing openwrt setup for first time.
GL.inet webinterface is easy for unexperienced users. So first learn understand openwrt with luci in GL.inet firmware. So no interests or need or time to learn openwrt, just keep your Flint on original GL.inet firmware.
