Flint fw 4.7.0 missing LOTS of packages
root@GL-AX1800:~# ./reinstallpackages.sh
Downloading https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/kmod-5.4.164/aarch64_cortex-a53_neon-vfpv4/ipq60xx/Packages.gz
Updated list of available packages in /var/opkg-lists/glinet_core
Downloading https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/packages-5.0/aarch64_cortex-a53_neon-vfpv4/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/opnwrt_packages
Updating database.
Database update completed.
Unknown package 'cJSON'.
Collected errors:
  • opkg_install_cmd: Cannot install package cJSON.
    Unknown package 'coreutils-stat'.
    Collected errors:
  • opkg_install_cmd: Cannot install package coreutils-stat.
    Unknown package 'ddns-scripts-services'.
    Collected errors:
  • opkg_install_cmd: Cannot install package ddns-scripts-services.
    Unknown package 'ddns-scripts'.
    Collected errors:
  • opkg_install_cmd: Cannot install package ddns-scripts.
    Unknown package 'etherwake'.
    Collected errors:
  • opkg_install_cmd: Cannot install package etherwake.
    Package htop (3.3.0-1) installed in root is up to date.
    Updating database.
    Package iftop (2018-10-03-77901c8c-2) installed in root is up to date.
    Updating database.
    Package iperf3 (3.10-1) installed in root is up to date.
    Updating database.
    Unknown package 'iputils-ping'.
    Collected errors:
  • opkg_install_cmd: Cannot install package iputils-ping.
    Package jq (1.6-2) installed in root is up to date.
    Updating database.
    Unknown package 'kmod-crypto-md5'.
    Collected errors:
  • opkg_install_cmd: Cannot install package kmod-crypto-md5.
    Package libcares (1.27.0-1) installed in root is up to date.
    Updating database.
    Unknown package 'libmosquitto-ssl'.
    Collected errors:
  • opkg_install_cmd: Cannot install package libmosquitto-ssl.
    Package libpcap1 (1.10.4-1) installed in root is up to date.
    Updating database.
    Unknown package 'libwebsockets-openssl'.
    Collected errors:
  • opkg_install_cmd: Cannot install package libwebsockets-openssl.
    Unknown package 'luci-app-ddns'.
    Collected errors:
  • opkg_install_cmd: Cannot install package luci-app-ddns.
    Unknown package 'luci-app-mosquitto'.
    Collected errors:
  • opkg_install_cmd: Cannot install package luci-app-mosquitto.
    Unknown package 'luci-app-tinyproxy'.
    Collected errors:
  • opkg_install_cmd: Cannot install package luci-app-tinyproxy.
    Unknown package 'luci-app-watchcat'.
    Collected errors:
  • opkg_install_cmd: Cannot install package luci-app-watchcat.
    Unknown package 'luci-app-wol'.
    Collected errors:
  • opkg_install_cmd: Cannot install package luci-app-wol.
    Package luci-compat (git-25.070.50735-0322352) installed in root is up to date.
    Updating database.
    Unknown package 'luci-lib-ipkg'.
    Collected errors:
  • opkg_install_cmd: Cannot install package luci-lib-ipkg.
    Unknown package 'mosquitto-client-ssl'.
    Collected errors:
  • opkg_install_cmd: Cannot install package mosquitto-client-ssl.
    Unknown package 'mosquitto-ssl'.
    Collected errors:
  • opkg_install_cmd: Cannot install package mosquitto-ssl.
    Package netperf (2.7.0-3) installed in root is up to date.
    Updating database.
    Unknown package 'nping'.
    Collected errors:
  • opkg_install_cmd: Cannot install package nping.
    Package screen (4.8.0-2) installed in root is up to date.
    Updating database.
    Package speedtest-netperf (1.0.0-1) installed in root is up to date.
    Updating database.
    Unknown package 'sshpass'.
    Collected errors:
  • opkg_install_cmd: Cannot install package sshpass.
    Unknown package 'tinyproxy'.
    Collected errors:
  • opkg_install_cmd: Cannot install package tinyproxy.
    Unknown package 'watchcat'.
    Collected errors:
  • opkg_install_cmd: Cannot install package watchcat.
All those packages were totally fine and working in previous firmwares. Please fix thix.
Do you even beta test? How long was 4.7.0 in beta test for Flint? How would you think this will work out?
@mkdr Hi, you may wish to join the thread re missing packages in 4.7.0 here: SlateAX, upgraded to 4.7.0, missing most packages
This is not just Flint affected, same with Slate (AXT1800), and all others that use this repo.
I updated my Brume 2 months ago to 4.7.0 and did not notice any packages missing, so it doesnt seem to be all fw with 4.7.0. For some reason Brume 2 got 4.7.0 way before others.
Good to know, I haven't upgraded mine yet after the Slate fiasco, guess Brume is a different build/arch?
