You went off scripted so I can’t help you anymore. I gave you a specific way to do it. If you set up a raspberry Pi you should be able to update uboot and the GL.iNet firmware.
Good luck
Check the vpn proxy settings in vpn dashboard if your wgclients are actually connected to may not be allowed to leave the LAN and use the WAN
If you look at the uboot thread Uboot needs to be updated to avoid issues going forword in firmware
To clarify - this morning I did the whole process again - uboot upgrade to uboot-gl-ax1800-20220711-md5-9890c67c3dafa5aec172f3a31583f9a7.bin
Then upgrade to openwrt-ax1800-4.2.0-0121-1674260559.tar
the client does not connect, the connection does not work
Where and what do I need to set?
In Luci? Because there is no other option in the Admin panel.
And when in Luci - what should I change there?
Something with routing? Because I’m not good at it.
Where can I find instructions for standard WG operation?
Isnt this done automatically when you enable WG server? I have tested with SlateAX and Flint on 4.1 and it works without having to open the ports on the FW.
I was primarily setting up firewall forward - to try wg on raspberry.
This worked for me even without an open port on the router. I didn’t realize they were two separate things.
My apologies and thanks again for your time. Everything good.
