Decided to go back to stable as V4 had issues with some of my firewall rules (I had to use the unbrick method to go back to V3)
AGAIN, even with stable version 3.214 I faced a lot of issues … So I thought, maybe I should reset to factory settings using the normal method (holding reset for 4 seconds) was the best idea (IT WAS NOT)
Bammmmm Flint stopped working, no lights even this time so the unbrick method didnt work
Is it really gone? is there anything I can do? I really liked this router.
Another reason why Admin panel must provide option to Reboot into Uboot Web UI it is already disgusting to mess with hardware reset buttons but THIS is like a warning sign
when I went back to 3.214 … it did boot fine, but I was not able to change it to access point mode for some reason, so I thought maybe reseting it would fix things … it did not
