I have been trying utilize the scheduled tasks on my Flint router. Turn off router and wifi works, though when turning wifi back on I have issues connecting back on wifi unless I reboot the router. is this normal?
Also though wifi clients (users on wifi network) is there a way to “kick” someone off the network remotely?
It does not have the ability to kick client devices out of Wi-Fi yet.
An alternative solution is to disable connections to the extranet. From the client page you can disable specific devices from connecting to the extranet. If you upgrade to the 4.2 firmware, you can prevent all newly accessed devices from connecting to the extranet until you manually allow it via the parental control feature.
The other is to receive notifications of new clients joining via GoodCloud. Modify your WiFi as soon as an unknown device is connected.
We have plans to develop access control features in version 4.4 or later. But not the “kick out of Wi-Fi connection” kind. It will prevent clients connected via Wi-Fi or cable from accessing any devices on the external network as well as the internal network.
