Flint GL-AX1800 TailsScale Exit Node Problem
Hi all, I am looking for somebody who can help me, I am struggling from long time, nobody was able to help me, a few people tried but never successfully.
I want to use my router as a VPN Server and connect ALL of my devices remotely to route all traffic via Router via active Proton VPN Client.
I did read and it's not a problem, I can do this but I don't know what I am doing wrong, what kind of configuration is missing.
I stuck in TailsScale admin panel as have to set up router in settings as exit node but this option is Gray out,
I used SHH command to do an advertising the exit node status in routes , not sure have I done it properly but still exit node settings is Gray out,
Is anyone who have a Good nowledge and want help please ???
I want to create a Immich server but I stuck on the beginning with creating a network…so I am not able remotely connect any devices with my router..
Thank you
LuKi
To implement the configuration you described, please refer to the following two guides.
The first guide explains how to configure the router as a Tailscale Exit Node:
The second guide explains how to route traffic received through Tailscale to the WireGuard VPN Client running on the router:
Since you have already run SSH command to do an advertising the exit node status in routes, could you please run the following commands on the router through SSH and provide the complete output?
tailscale version
tailscale status
tailscale debug prefs
grep -n "tailscale up" /usr/bin/gl_tailscale
These commands only check the current Tailscale status and startup parameters and will not modify the router configuration.
The output will help us confirm whether the router is still advertising the Exit Node routes and whether the setting may have been overwritten after Tailscale was restarted or the settings were applied again in the web interface.
Thank you for your cooperation.
