any way to change ath0 ath1 mac addresses?
option macaddress is ignored.
it’s option macaddr.
LOL are you sure it works?
I thought they put macaddress in device section to refer hardware not spoof mac address.
On “normal” openwrt I use that option in interace section not device section so for example guest ssid has different mac address, but with your approach i would still end up with two ssids on same mac address right?
Okay, macaddr can also be applied to iface section. After patching system file like this:
sed -i 1941a'config_get bssid "$vif" macaddr' /lib/wifi/qcawificfg80211.sh
It will be merge to next release of firmware.
Thanks.
