So I was playing a little with the wireguard client config in specific with allowed_ips to play a little to experiment if I could manual add my vpn bypass over my vlan.
But when I used /etc/init.d/wireguard restart
my connection becomes unresponsive, even if I rollback my action and using the same command it will be unresponsive again, only rebooting gives me a working internet connection over wireguard and on the ui it works too, I’m using the wrong daemon command ?
I feel I might found a bug here, I’m not sure what happens when WAN has connectivity loss for example by isp maintenance but wireguard might not reconnect in such scenario?
Edit:
Yes I have tried to restart stubby aswell but it wont give me connection, it refuses all connections at that moment, and im using busybox 1.28.3_4 and ipv6 and rebinding is off.
