So I have this in log every second, do you know how to track what is causing this?
Thu Oct 23 11:38:52 2025 kern.warn kernel: [59296.949400] 7986@C13L2,PeerAddBARspActionSanity() 248: ADDBA Resp Ba Policy[0] not support
Thu Oct 23 11:38:54 2025 kern.warn kernel: [59298.998254] 7986@C13L2,PeerAddBARspActionSanity() 248: ADDBA Resp Ba Policy[0] not support
Thu Oct 23 11:38:56 2025 kern.warn kernel: [59300.436187] 7986@C13L2,PeerAddBARspActionSanity() 248: ADDBA Resp Ba Policy[0] not support
This appears to be a common compatibility issue with Apple Watch clients.
Please try disconnecting Wi-Fi clients one by one until the message no longer appears in the logs.
If you identify specific Apple Watch devices causing the issue, try restarting them or updating their system version to see if it helps.
In general, this message does not affect network functionality and can be safely ignored.
Ok, I have 40+ devices, but none of it is Apple. I will try your debugging method, maybe there is some other manufacturer that also has this compatibility issue.
I just noticed the same and mine ended up being Apple HomePod Mini’s. I’ve also read reports of same with doorbells and thermostats, so perhaps something ‘home’ related? Everything on latest updates / firmware.
