Flint2 problem day
and for a few days now that I've been having problems with flint2 I find it disconnected from the wireguard VPN and then to reconnect I have to restart everything
  1. Firmware version?
    Did you try this one? GL.iNet download center
  2. What VPN provider are you using?
  3. Share the logs, so the developers can take a look
https://dl.gl-inet.com/router/mt6000/stable
4.6.8
Hw did yo verify that the issue is not with wireguard vpn it self or VPN provider??
I'm using Firmware 4.6.8 since it was released and I never experienced this issue.
So try to answer the remaining 2 items from my previous comment.
I have never had this problem before using this firmware I use and tried both shark and private vpn
ma perche se metto la beta 4.7 in aggiornamento manuale non me la accetta?
Ciao. Cosa vorresti dire con "non me la accetta"?
C'è qualche messaggio d'errore?
messaggio errore in rosso
Certo, ma quale messaggio? Cosa c'è scritto?
Adesso funziona ma non so se conviene farlo visto che e una beta
Please stick with english or use PMs.
the problem could be AdGuard enabled ? is disable......
