After purchasing the GL-MT6000, I installed the OpenWrt firmware. I am currently using version OpenWrt 24.10.03. However, the Wi-Fi network is not working satisfactorily for me. I’ve read that the factory firmware uses a different Wi-Fi driver, and I would like to revert to the stock firmware. Is it enough to use the “Flash new firmware image” function in OpenWrt and upload the firmware from https://dl.gl-inet.com/router/mt6000/stable, or do I need to use a different method?
That should work, thankfully you can go back and forth easily with the Flint2 firmwares, try no to keep settings on any direction ![]()
