Hi all. Maybe misleading topic a bit. I'm just thinking, because MLO is only wpa3, not all devices in my network are wpa3 compatible. Will it be good idea to enable MLO and all other WiFi networks (2.4,5,6Ghz) all using the same SSID. Let's say I want to have same SSID. Seems working just OK, but not sure on radio level, are devices struggling to connect, keep connection? More issues predictable? Any input on this?
This is generally depended on the client's capabilities.
If the devices such as smart home, may be better to set 2.4GHz as a unique SSID separately, since the WiFi compatibility of the smart home devices may only be connected to 2.4GHz WPA/WPA2 WiFi.
You can do a test based on your network environment.
