Hi all!
Well, I finally bought some new router after 10 years of living with my Turris Omnia, so I would like to say few words.. Main reason to buy, was my new NAS with 10Gbps LAN.
First look and setup:
Beatiful design (subjective) and great build quality. Display is not as useless as I thought.
First setup was a little bit tricky for me. I thought, that if some port is marked as WAN, it suppose to work as WAN from the first time. I plugged my wan cable into 2,5Gbps port, as I am using 10Gbps for NAS. Even when plugged to 10Gbps port, router gave me ip not from LAN, but my external IPv4 178.x.x.x. The cable had to be fully disconnected to cover this.
My advice to developers: First setup should cover this somehow.
Next step I went to 4.11 beta3 as I knew that VLANs and firewall settings would not work if they are set on old openwrt.
After, everything was set, I have noticed, that my phones are unable to connect to the wifi. After the router reboot, even my laptop was unable to connect. This was probably by some settings combination (I suspect masquerading on wgclient setup) as I have turned on almost everything, so I don’t blame anyone else except me (+ Google Gemini which helped me a little) :-)
So, reset to factory → flash to 4.9.2 and all settings again…
During the setting of wireguard client (site-2-site), I have noticed, that some guide/options were missing in 4.11, comparing to 4.9.2.
Bugs found:
Device IP cannot be set as static via GlinetUI when it is on another subnet (e.g. IoT). The only option working is from LuCI.
Known: AdGuard Home update works only, when site-2-site wireguard tunnel is turned off. Workaround is script in LuCI scheduled tasks: 0 3 * * * ubus call network.interface.wgclient1 down && sleep 10 && /usr/bin/adguardhome --update-filters && sleep 20 && ubus call network.interface.wgclient1 up
Wish-list:
I hope, there will be some script to move settings form Openwrt 21 to Openwrt 25 (Turris team managed changes for VLANS and Firewall almost excellently).
Live updates and Snapshots as on the Turris Omnia.
LAN bandwidth displayed on the router display and GlinetUI.
Possibility to edit display entries (I don’t need to see cellular or tethering on it…).
Conclusion:
Beautiful and functional (comparing to reForis UI on Omnia) GlinetUI, very good wifi coverage (even 6GHz is available everywhere) and some bugs, which hopefully will be solved.
So far, I am satisfied.
