For what can the SD card be used with the Spitz AX-3000?
Can I increase the internal memory?
Can I install more packages?
What format I have to use ext4, FAT, exFAT?
If I have one already installed, how can I format it?
Thanks
Can you see the device node of the SD card on the X3000?
If it generated a device node: /dev/sda,you can exec the followint:
fsck.ext4 /dev/sda
