Force Lte 4G
<p style=“text-align: left;”>Hi, I have mifi with the <span style=“background-color: #f9f9f9; color: #222222; font-family: source_sans_proregular, ‘Helvetica Neue’, Arial, Helvetica, Geneva, sans-serif; font-size: 14.6667px;”>EC20-E 4G EU module.</span></p>
<p style=“text-align: left;”>But I can’t connect to 4G.</p>
<p style=“text-align: left;”>It automatically goes to 3G and I can’t change it.</p>
<p style=“text-align: left;”>How can I force it to 4G?</p>
<p style=“text-align: left;”>I’m from Australia on the Optus network.</p>
<p style=“text-align: left;”>Thanks.</p>
<p style=“text-align: right;”></p>
Hi, I have mifi with the EC20-E 4G EU module.
But I can’t connect to 4G. It automatically goes to 3G and I can’t change it.
Thanks.
This has been added to docs
http://www.gl-inet.com/docs/mini/mifi/#at-commands
Choose network mode
set modem to only LTE
echo -e "AT+QCFG=\"nwscanmode\",3,1" > /dev/ttyUSB2
set back to auto
echo -e "AT+QCFG=\"nwscanmode\",0,1" > /dev/ttyUSB2
Thank you. Got it!
@alzhao
Fancy meeting you here
I still have the issue that
I’ve been using
AT+QCFG=“nwscanmode”,3,1
to lock to LTE, and it works when I check the value… But it doesn’t survive a reboot.
I think it should survive a reboot of the device.
Any thoughts on that? When you execute the command, what ‘port’ are you sending it to?
The command should survive a reboot.
Not sure why in your case.
Except for force LTE, can you try lock band?
Have you contacted me by email?
@luochongjun Yes, we chatted by email. It is supposed to survive a reboot but doesn’t. I’m busy trying to get the device to stay connected, so chasing the LTE issue is secondary. But it should still work.
