FortiClient VPN issues with GL-MT6000 (Flint2) router
My organization switched to FortiClient VPN recently, and it does not function correctly through my home GL-MT6000 router.
FortiClient injects a primary DNS on my work laptop in the 100.64.0.0 IP subnet, and all DNS traffic from the laptop fails.
The FortiClient VPN works correctly via a mobile hotspot. I have had no trouble with other VPNs traversing the router.
These are some of the troublshooting steps I have attempted:
  • set firewall rules to allow all traffic to and from this device at the top of the rule list.
  • installed MiniUPnP and set it to allow UPnP requests only from this device.
  • started with Admin Panel version 4.7.7, then upgraded to 4.8.2.
None of these have had any impact on the FortiClient DNS issue.
Could you please provide us with some more details so we can further check?
  1. Does FortiClient connect successfully or not?
  2. After connecting, please run the following commands on your Windows(?) laptop and share the results:
ipconfig
route print
  1. Please also ensure no other VPN or proxy software is running at the same time, including Tailscale or ZeroTier.
  1. FortiClient connects successfully. The console shows traffic. However DNS fails.
    I cannot ping the default gateway nor the primary DNS server for the FortiClient interface, but I can ping internet IPs (1.1.1.1).
    I’ve set the router to provides 1.1.1.1 the DNS server via DHCP. When FortiClient connects, it pushes 1.1.1.1 to secondary and replaces primary with their 100.64.x.x subnet DNS server for the duration of the FortiClient connection.
    My browsers and office software are configured such that both require connected FortiClient VPN to function.
  2. Connected via GL-MT6000 - no FortiClient
    ipconfig /all (connected interfaces)
    Ethernet adapter Ethernet 2:
       Connection-specific DNS Suffix  . : lan
       Description . . . . . . . . . . . : Realtek USB GbE Family Controller
       Physical Address. . . . . . . . . : redacted
       DHCP Enabled. . . . . . . . . . . : Yes
       Autoconfiguration Enabled . . . . : Yes
       IPv4 Address. . . . . . . . . . . : 192.168.1.173(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.255.0
       Lease Obtained. . . . . . . . . . : Monday, September 8, 2025 10:15:25 PM
       Lease Expires . . . . . . . . . . : Tuesday, September 9, 2025 8:48:55 PM
       Default Gateway . . . . . . . . . : 192.168.1.1
       DHCP Server . . . . . . . . . . . : 192.168.1.1
       DNS Servers . . . . . . . . . . . : 1.1.1.1
       NetBIOS over Tcpip. . . . . . . . : Enabled
    route print
    Interface List
     13...redacted          ......Intel(R) Ethernet Connection (13) I219-LM
     12...redacted          ......Fortinet SSL VPN Virtual Ethernet Adapter
     19...redacted          ......Realtek USB GbE Family Controller
     20...redacted          ......Fortinet Virtual Ethernet Adapter (NDIS 6.30)
     18...redacted          ......Microsoft Wi-Fi Direct Virtual Adapter
      2...redacted          ......Microsoft Wi-Fi Direct Virtual Adapter #2
     23...redacted          ......Intel(R) Wi-Fi 6 AX201 160MHz
      1...........................Software Loopback Interface 1
    IPv4 Route Table
    Active Routes:
    Network Destination        Netmask          Gateway       Interface  Metric
              0.0.0.0          0.0.0.0      192.168.1.1    192.168.1.173     25
            127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
            127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
      127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
          192.168.1.0    255.255.255.0         On-link     192.168.1.173    281
        192.168.1.173  255.255.255.255         On-link     192.168.1.173    281
        192.168.1.255  255.255.255.255         On-link     192.168.1.173    281
            224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
            224.0.0.0        240.0.0.0         On-link     192.168.1.173    281
      255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
      255.255.255.255  255.255.255.255         On-link     192.168.1.173    281
    Persistent Routes:
      None
    IPv6 Route Table
    Active Routes:
     If Metric Network Destination      Gateway
      1    331 ::1/128                  On-link
      1    331 ff00::/8                 On-link
    Persistent Routes:
      None
    Connected via GL-MT6000 - FortiClient connected
       Lease Expires . . . . . . . . . . : Tuesday, September 9, 2025 8:48:54 PM
       DNS Servers . . . . . . . . . . . : 100.81.0.1
                                           1.1.1.1
    Ethernet adapter Ethernet 4:
       Description . . . . . . . . . . . : Fortinet Virtual Ethernet Adapter (NDIS 6.30)
       IPv4 Address. . . . . . . . . . . : 10.247.144.142(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.255.255
       Lease Obtained. . . . . . . . . . : Tuesday, September 9, 2025 8:49:43 AM
       Lease Expires . . . . . . . . . . : Friday, October 16, 2161 3:18:04 PM
       Default Gateway . . . . . . . . . : 10.247.144.143
       DHCP Server . . . . . . . . . . . : 10.247.144.143
                                           0.0.0.0
    route print
    Interface List
    IPv4 Route Table
    Active Routes:
              0.0.0.0          0.0.0.0   10.247.144.143   10.247.144.142     26
       10.247.144.142  255.255.255.255         On-link    10.247.144.142    281
            224.0.0.0        240.0.0.0         On-link    10.247.144.142    281
      255.255.255.255  255.255.255.255         On-link    10.247.144.142    281
    Persistent Routes:
      None
    IPv6 Route Table
    Active Routes:
    Persistent Routes:
      None
    Connected via hotspot - FortiClient connected
       IPv4 Address. . . . . . . . . . . : 10.247.112.129(Preferred)
       Lease Obtained. . . . . . . . . . : Tuesday, September 9, 2025 8:03:15 AM
       Lease Expires . . . . . . . . . . : Friday, October 16, 2161 3:07:20 PM
       Default Gateway . . . . . . . . . : 10.247.112.130
       DHCP Server . . . . . . . . . . . : 10.247.112.130
                                           0.0.0.0
    Wireless LAN adapter Wi-Fi:
       Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX201 160MHz
       IPv4 Address. . . . . . . . . . . : redacted
       Lease Obtained. . . . . . . . . . : Tuesday, September 9, 2025 8:02:17 AM
       Lease Expires . . . . . . . . . . : Tuesday, September 9, 2025 9:32:14 AM
       Default Gateway . . . . . . . . . : redacted
       DHCP Server . . . . . . . . . . . : redacted
                                           redacted
    route print
    Interface List
    IPv4 Route Table
    Active Routes:
              0.0.0.0          0.0.0.0   redacted (hotspot)    redacted (hotspot)     35
              0.0.0.0          0.0.0.0   10.247.112.130   10.247.112.129     26
       10.247.112.129  255.255.255.255         On-link    10.247.112.129    281
         44.232.12.97  255.255.255.255   redacted (hotspot)    redacted (hotspot)    134
       54.190.240.168  255.255.255.255   redacted (hotspot)    redacted (hotspot)    134
       54.200.120.146  255.255.255.255   redacted (hotspot)    redacted (hotspot)    134
       54.200.215.134  255.255.255.255   redacted (hotspot)    redacted (hotspot)    134
       168.250.53.214  255.255.255.255   redacted (hotspot)    redacted (hotspot)    134
         redacted (hotspot)    255.255.255.0         On-link     redacted (hotspot)    291
        redacted (hotspot)  255.255.255.255         On-link     redacted (hotspot)    291
       209.40.109.186  255.255.255.255   redacted (hotspot)    redacted (hotspot)     35
            224.0.0.0        240.0.0.0         On-link    10.247.112.129    281
            224.0.0.0        240.0.0.0         On-link     redacted (hotspot)    291
      255.255.255.255  255.255.255.255         On-link    10.247.112.129    281
      255.255.255.255  255.255.255.255         On-link     redacted (hotspot)    291
    Persistent Routes:
      None
    IPv6 Route Table
    Active Routes:
    Persistent Routes:
      None
  3. There are no other VPNs on this laptop nor any at the router level.
Please disregard. I connected the laptop directly to the modem and the issue persists. This is an ISP issue.
Thank you for swift response and your attention to this matter!
This appears to be caused by Windows/FortiClient not correctly setting the routing metric.
# GL-MT6000 - FortiClient connected
# hotspot - FortiClient connected
Please try manually increasing the metric for Ethernet adapter Ethernet 2 by:
https://www.tenforums.com/tutorials/92180-change-network-adapter-connection-priorities-windows-10-a.html
@will.qiu You were absolutely correct. Thank you so much!
We decreased the metric for the 10.x.x.x gateway (Interface index 20 on my laptop) with the following PowerShell command run as administrator:
```powershell
Set-NetIPInterface -InterfaceIndex 20 -AutomaticMetric Disabled -InterfaceMetric 2
Now DNS and everything else routes properly. No router issue, no ISP issue, simple configuration of the VPN interface.
