Frustrating VPN Error on AR-750S "WARNING: No internet"
#1
Hi I purchased 10 of these routers for my employees specifically for their VPN functionality.
I want to purchase 20 more but I cannot get the VPN functionality working in our office and this is VERY frustrating.
Every OpenVPN or Wireguard connection attempt results in a “WARNING: No internet” warning. Every LAN client can access the internet just fine, and our LAN clients can even connect to the same exact VPNs fine through the GL.inet router. This is a bug in your software.
Can you completely remove the “WARNING: No Internet” check, and just try to connect to OpenVPN or Wireguard anyways? Or provide an option to disable it? Or give me a custom build so I can buy more of these?
On every single RFC1918 connection I have tried, this error shows even if there is internet access. Here is our exact configuration
WAN IP: 192.168.25.242
WAN Subnet: 192.168.25.240/28
LAN IP: 192.168.8.1
LAN Subnet: 192.168.8.1/24
Tested across multiple networks for two months, reaching out for help. Thank you.
#2
Also please add back two important features from the old firmware:
  • A checkbox to disallow internet access when VPN is disconnected - not always enabled (I do not want to always default true, especially if connecting to corporate private VPN which is not advertising default route)
  • Tailing of the OpenVPN log files
Thank you for your excellent products I have used for years, this new firmware is beautiful design, just needs some quick bug fixes.
#3
Can you put it in the bug tracker? The devs will take a look at it :slight_smile:
Make them separate issues :slight_smile:
#5
Unfortunate.
Okay I submitted some bugs.
The “WARNING: No internet connection” error is the MOST urgent for us, we want to buy more as soon as this is fixed!
#6
Business users do get some priority for feature requests compared to regular customers.
Check back on the status of the bug report and if it’s not fixed, send a message to @alzhao :slight_smile:
#7
It seems that this issue was fixed. Could you please upgrade to the latest testing firmware? http://download.gl-inet.com/firmware/ar750s/snapshots/
Firmware has openvpn problem
#8
I already tried this snapshot and it is now impossible to change servers within the same configuration - it lists servers from another config even though they are correct in /confog/ovpnclients.
As an aside, in my opinion it would be better to list the configs in /etc/openvpn by name instead of ovpn0, ovpn1 etc, as I could only recognize the profile by looking at the password and username combo.
