Why I'm sharing this with the community
Many of us bought the GL-BE9300 to take advantage of its next-gen hardware (Wi-Fi 7, 10Gbps, IPQ5332), but the Qualcomm SDK is extremely strict. Manually configuring VLANs often breaks Wi-Fi or causes permission errors.
I’ve reverse-engineered the qcawificfg80211 drivers and the system bridge structure to unlock this potential. I believe the hardware should serve the user, and my goal is for everyone to have a segmented, secure, and ultra-fast network without the headache.
Full Integration with GL-iNet
This is not a modified firmware; it’s a professional optimization that does not break factory features. You will still have:
- VPN (WireGuard/OpenVPN): 100% functional.
- AdGuard Home: Active filtering on all new VLANs.
- Tailscale: Remote access remains intact.
- GL.iNet Panel: Full stability and compatibility with native services.
SECURITY WARNING
This script is 100% functional, but the Qualcomm Lithium SDK is very sensitive. - Do not modify variables unless you know what you are doing, or the router might enter a crash loop.
- Risk: A bad internal switch configuration can turn your router into a nice and expensive paperweight (requiring U-Boot recovery).
- Recommendation: Use it exactly as provided after a Factory Reset.
Prerequisites - Access via SSH.
- Install an editor: opkg update && opkg install nano.
The Master Script
This script configures Port 3 as a Trunk, creates VLANs 10-50, brings up the corresponding Wi-Fi 7 SSIDs, and ensures Firewall isolation.
Instructions: - Create the file: nano setup_vlan.sh
- Paste the code below. IMPORTANT: Find the line set wireless.wifi_vlan$v.key and change 'YOUR_PASSWORD' to your desired one.
- Save (Ctrl+O), Exit (Ctrl+X), and run: chmod +x setup_vlan.sh && ./setup_vlan.sh
#!/bin/sh
# Master Script: Reverse Engineering Qualcomm Lithium BE9300
# Configures VLANs 10-50, Wi-Fi 7 SSIDs, and Bridges with persistence
echo "=== 1. Configuring Switch and Bridges (Port 3 Trunk) ==="
uci batch <<EOF
# Switch Config (Port 3 as Trunk, CPU on 6t)
delete network.@switch_vlan[0]
for v in 10 20 30 40 50; do
add network switch_vlan
set network.@switch_vlan[-1].device='switch1'
set network.@switch_vlan[-1].vlan="\$v"
set network.@switch_vlan[-1].ports='6t 3t'
# The Secret: Create a Layer 2 Bridge for the Qualcomm driver
set network.VLAN_\$v=interface
set network.VLAN_\$v.type='bridge'
set network.VLAN_\$v.ifname="eth1.\$v"
set network.VLAN_\$v.proto='static'
set network.VLAN_\$v.ipaddr="192.168.\$v.1"
set network.VLAN_\$v.netmask='255.255.255.0'
done
commit network
EOF
echo "=== 2. Configuring Wireless (qcawificfg80211 Driver) ==="
uci batch <<EOF
# Create SSIDs linked to bridges (VLAN 50 remains wired-only)
for v in 10 20 30 40; do
set wireless.wifi_vlan\$v=wifi-iface
set wireless.wifi_vlan\$v.device='wifi0'
set wireless.wifi_vlan\$v.network="VLAN_\$v"
set wireless.wifi_vlan\$v.mode='ap'
set wireless.wifi_vlan\$v.ssid="GL-BE9300-VLAN\$v"
set wireless.wifi_vlan\$v.encryption='psk2'
set wireless.wifi_vlan\$v.key='YOUR_PASSWORD_HERE'
done
commit wireless
EOF
echo "=== 3. Firewall and DHCP (Isolation & WAN) ==="
# Firewall Zone
uci set firewall.vlan\$v=zone
uci set firewall.vlan\$v.name="VLAN_\$v"
uci set firewall.vlan\$v.network="VLAN_\$v"
uci set firewall.vlan\$v.input='ACCEPT'
uci set firewall.vlan\$v.forward='REJECT'
uci set firewall.vlan\$v.output='ACCEPT'
# WAN Forwarding
uci add firewall forwarding
uci set firewall.@forwarding[-1].src="VLAN_\$v"
uci set firewall.@forwarding[-1].dest='wan'
# DHCP Server with AdGuard Home support (Option 6)
uci set dhcp.VLAN_\$v=dhcp
uci set dhcp.VLAN_\$v.interface="VLAN_\$v"
uci set dhcp.VLAN_\$v.start='100'
uci set dhcp.VLAN_\$v.limit='150'
uci set dhcp.VLAN_\$v.leasetime='12h'
uci add_list dhcp.VLAN_\$v.dhcp_option="6,192.168.\$v.1"
done
uci commit firewall
uci commit dhcp
echo "=== 4. Restarting services in background ==="
sleep 2
/etc/init.d/network restart > /dev/null 2>&1 &
sleep 5
/etc/init.d/firewall restart > /dev/null 2>&1 &
/etc/init.d/dnsmasq restart > /dev/null 2>&1 &
wifi down && wifi up > /dev/null 2>&1 &
echo "Process finished. The network will stabilize in a few seconds."
FAQ: Frequently Asked Questions
- Will I lose speed? No. By using native bridges, the Qualcomm chip utilizes its hardware acceleration.
- Why did my SSH disconnect? This is normal. The router restarts the switch to apply VLANs. Wait 30 seconds and log back in.
- Can I change the Wi-Fi names? Yes, edit the script where it says ssid=, but keep the rest of the structure intact.
