Generally: Outdated Package Repos. Specifically: syncthing
Hello GL.iNet Forum,
Rexcellent here. New to the GL.iNet community but not new to OpenWRT. This is probably not a new topic, and I know that many package repositories suffer from outdated package versions, but I was wondering if GL.iNet has a way of marking packages that need to be updated?
Specifically, I’m a big fan of syncthing and it worked wonderfully on my new GL-MT3000 Beryl AX while on vacation. I wanted to update syncthing to the latest version 1.27 in order to address CVE-2022-46165. After downloading the package list from an “opkg update” command, I noticed that syncthing was at version 1.18.
The good news is, I was able to get syncthing 1.27 working on my Beryl AX, but it was not as “elegant” as enabling it through the GL.iNet Admin Panel (btw: I upgraded to firmware 4.6 just to try it out)
For a company that uses OpenWRT and sells products based on the notion of open-source software and security, I think it would be a nice touch to be able to identify out of date packages.
In any event, I am very satisfied with my Beryl AX, and I look forward to discovering the different things I can do with this handy device. Please keep up the good work.
Thank you for your attention.
I’d love to see a focus more on security by making it simple to update out of date packages, especially ones with known vunlerabilities.
The main problem is that OpenWrt 21.x is EOL, so there are no new packages - if nobody backport them. You can always try to install newer packages, but this will often fail because the main OS version changed.
So I don’t think this problem can be resolved soon, at least not as long as the base OS isn’t the newest OpenWrt.
