Generating a tailscale certificate does not work
I'm glad that the latest Beryl 4.8.0 firmware included an updated tailscale binary.
Its certificate issuing feature is not working though:
tailscale cert beryl.antani-mario.ts.net
Get "http://local-tailscaled.sock/localapi/v0/cert/beryl.antani-mario.ts.net?type=pair&min_validity=0s": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
Might you want to investigate on this and fix it? Being able to access the router from anywhere via tailscale is exceptionally good, but doing it with a proper SSL certificate would be the msot perfect and safest thing.
Thanks,
I can also reproduce this issue, the interface of tailscaled process is suspected to be unresponsive.
GL firmware does not support this feature for the time being, we need to check it out.
Thanks for caring. I really think this would add a lot of value to these routers with tailscale.
