I flash my mt300n with some other firmware, when i flash back the original firmware , the GLI GUI is gone . It went direct to the openwrt standard login.
Anyway, i can get back the GLI GUI? flash with different version from 2.14 to 2.19 yield the same result.
I’d like to try out the pure openWRT - to see if my speeds will be better. Right now, I cannot seem to get past 3Mbit, and rarely see 4Mbit download speeds.
Putting ? at the end should work to clear the cache for you too. What source are you using for your Internet? Remember, OpenWRT is what’s under the hood on your current router and GLi’s excellent interface isn’t going to slow things down. If anything you’re likely to see a very small change.
@<span style=“color: #222222; font-family: source_sans_proregular, ‘Helvetica Neue’, Arial, Helvetica, Geneva, sans-serif; font-weight: bold; line-height: 22px; background-color: #f9f9f9;”>Mmonaghan - </span>doesn’t seem to matter… if i use my phone’s hotspot or my home router’s guest hotspot.
I get better speeds out of my TP-Link MR710N w. OpenWRT
If you want something that will be good for the long term, you’ll need to compile it. For testing you can pull from Trunk Snapshots. This should be the right file:
