Getting back to GLI GUI on GL-AR750S
My GL-AR750S is only 2-3 months old. I have never flashed/updated anything since purchased, but for some reason when I booted it up this morning I can only get to the LUCI interface. Going to 192.168.8.1/index.html just redirects to the LUCI clean OpenWRT login.
Everything else is otherwise working fine, but is there a way to go back to the GLI GUI easily? or would I need to do a factory reset or GL firmware flash and lose settings?
This is often related to browser caching. I’d first try an “incognito” window and going directly to http://192.168.8.1/ to see if that resolves it. (That way you don’t need to completely clear your browser, or try to figure out how to selectively clear its cache.)
Thanks jeffsf, that was the issue! I thought I had cleared my cache but apparently not enough.
I tried from another fresh host and got right to it.
