Hi there,
I am looking for a solution to enable me to work while away from home. The GL-A1300 looks like it will do the job but I am not sure.
At home I have landline router with the settings
gateway 192.168.0.1
DHCP Network Range 192.168.0.4 - 192.168.0.255
I use Virtualbox Debian Servers on my Windows 10 laptop - used for Wordpress software development - with these server settings
/etc/network/interfaces
auto lo
iface lo inet loopback
auto enp0s3
iface enp0s3 inet static
address 192.168.0.202
netmask 255.255.255.0
gateway 192.168.0.1
When travelling I want to connect my Android phone with “USB Tether” to GL-A1300 and have my servers connect without having to alter their settings.
I am aware that the IP address on the tether is dynamic and that this can affect the DHCP setup on some routers. It’s all a bit confusing.
Would appreciate advice on whether the GL-A1300 will be suitable - or alternatives ?
Thanks.
