My GL-A1300 is running Firmware 4.0.0 beta2. I am unable to manually upload an OpenVPN config file. It shows as Upload Successful, but then is not listed and the config file is not uploaded to /etc/openvpn/profiles folder. I also tried unsuccessfully to manually upload a NordVPN OpenVPN config file I downloaded from their website. The router is successful in automatically downloading from NordVPN provider directly. I am able to successfully manually upload WireGuard config files.
Upload Successful:
No config listed:
Upload Successful:
No config listed:
Automatic download from NordVPN provider directly works:
Only config files form the automatic download from NordVPN:
EDIT:
The problem appears to be that file names cannot have spaces/blanks. I was able to update OpenVPN config files after removing changing spaces/blanks to “.”.
I don’t think it should Upload Successful if it is not and I note that the GL-AXT1800 accepts file names with spaces/blanks.
seems you’re using repeater and tethering at the same time, right? If only using one works?
Just test a1300’s wireguard client, connecting ax1800 wireguard server, it works.
If your wgclient interface has some traffic?like this
I’ve got it today. First tests are not very hard. But as it is my third router, I already know you guys are making a great job.
One thing, so far: I can’t find the configuration for the VPN switch on the side. Since the routing isn’t working (connecting well but no routing to the internet. It could be an issue on my side, at the moment my home network is renewed completely) I really miss this feature, know from the Beryl/Slate AX.
Edit:
Too late … I second this one: GL-A1300 Beta Testing Discussions - #6 by wcs2228
One issue I have noticed is with the LED config in Luci. When you set white LED to off and save and apply it defaults to back on. It works fine for network activity but the blue LED cannot be configured at all. It shows briefly that the setting was applied but that defaults to off and the white defaults to on unless set to netdev for network activity.
I wanted blue for rx and white for tx but it doesn’t work. Please can this be fixed.
Although I would also like to see config options within the main UI for the LED.
I second that the Blue light LED configuration never takes effect.
The default led behaviour is to indicate wan network, pls try to stop led service and then config by luci
/etc/init.d/gl_led disable
/etc/init.d/gl_led stop
my testing GL-A1300 upgrade to V4.0 beta2 for day.
I met questions
1.Admin panel - clients some clients show Nan undefined/s in speed (not always)
2.plug-in the USB to SATA 120G ssd but not show in
Admin panel - applications - network storage
logread.zip (14.7 KB)
The log “ess_edma c080000.edma: IPv6 not supported” is abnormal. We’ll investiagting this.
Does you ssd need power plug? Could you tell what its model?
Thank you for provide detailed steps. These two days we’ll relase beta3, that fix a spi nand related issue, that may cause abnormal high memory occupation.
Could you provide a backup of route configs at luci page http://192.168.8.1/cgi-bin/luci/admin/system/flash
you can remove your mullvad and nextdns and account related infomation.
sent it to email handongming#gl-inet.com
I’ll test new release. My Slate plus in vpn intensive streaming crash for too memory used…
I noticed that vlan via wan may does not work in this case my configuration:
  • AX6S the modem, has a network tagged with vlan id 53, and vlan 1 is untagged which should be the default.
Then my tp-link sg-1016de receives the tag on port 0 which is wan so I check this checkbox on port 0 for id 53 and I also select port 7 for vlan id 53 which is the port connected to the A1300, and all the other ports are untagged, see screenshot for reference:
now on the A1300 I just add a dhcp client with network: eth1.53 and it doesn’t get dhcp, I compared the behaviour with flint, and for flint it does work, something with the switch seems to be not right.
A1300 = beta2
Flint = 4.0.1 Beta2
note: port 5 was tagged for flint I forgot to check it again cus I removed the setup again :stuck_out_tongue:
Customer Service in Shenzhen said ,we can chat with Chinese ,I will type Chinese after that
我知道你想说的,那种情况仅限于台式机的HDD(3.5 inch),现阶段我尚未见过需要额外12V供电的2.5 inch的HDD和SSD,在这个案例中,我强调了用的是120G SSD
此外,也可以在
这份日志文件中找到设备识别到该硬盘的相关日志
摘抄部分日志
Tue Aug 16 14:59:05 2022 kern.info kernel: [62014.312014] usb 2-1: new SuperSpeed Gen 1 USB device number 4 using xhci-hcd
Tue Aug 16 14:59:05 2022 kern.info kernel: [62014.352479] scsi host0: uas
Tue Aug 16 14:59:05 2022 kern.notice kernel: [62014.363424] scsi 0:0:0:0: Direct-Access tigo SSD 120GB 0 PQ: 0 ANSI: 6
Tue Aug 16 14:59:05 2022 kern.notice kernel: [62014.365894] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Tue Aug 16 14:59:05 2022 kern.notice kernel: [62014.371332] sd 0:0:0:0: [sda] Write Protect is off
Tue Aug 16 14:59:05 2022 kern.debug kernel: [62014.377975] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
Tue Aug 16 14:59:05 2022 kern.notice kernel: [62014.378386] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Tue Aug 16 14:59:05 2022 kern.info kernel: [62014.383153] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
Tue Aug 16 14:59:05 2022 kern.info kernel: [62014.439089] sda: sda1 sda2
Tue Aug 16 14:59:05 2022 kern.notice kernel: [62014.445531] sd 0:0:0:0: [sda] Attached SCSI disk
Pls try setup by command:
uci set network.wan.device='eth1.53'
uci commit network
/etc/init.d/network restart
麻烦尝试如下命令看能否识别:
echo 152d:1561:u >/sys/module/usb_storage/parameters/quirks
来自链接
将152d:1561换成对应的vid和pid。
这样可以看vid和pid
cat /sys/kernel/debug/usb/devices
并没有正常显示在页面中,请查看日志和相关命令日志
logread220818.zip (17.8 KB)
若在插在设备的情况下重启路由器可以正常挂载并显示在界面中
Hey guys, new beta version is released.
Important bugfix:
Fix the opkg update report failure.
Fix crash log not work.
Fix upload vpn configuration fail when filename has spaces.
Fix the U disk wrongly recognized as sd card.
Fix nand data loss.
Add switch buton configuration.
Remaining issues:
nginx/system crash when high memory usage.
Thanks.
好的,能是usb驱动的问题,我们在试试。
Sorry man, latest beta3 relase build missed CONFIG_ATH10K_THERMAL=y config, so this will be fixed a few days later.
请问可以告诉我们你的硬盘型号吗? 我们拿其他型号的硬盘测试没有问题
