GL-A1300 VPN confused
I am new to these routers so forgive me if I'm doing a rookie mistake.
I have my GL-inet router connected to the hotel wifi network and all my devices in the room work.
But I would like to access TV programmes back in the UK and have accessed my NordVPN account from the openVPN in the router, selecting one of the many options in the list. When I start the VPN via the 3 dots I can see a yellow dot on the left that never turns green.
What am I doing wrong, please?
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Rule 'process_mark'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Rule 'wan_in_conn_mark'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Rule 'lan_in_conn_mark_restore'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Rule 'out_conn_mark_restore'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Zone 'lan'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Zone 'wan'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Zone 'guest'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Zone 'ovpnclient'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Set tcp_ecn to off
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Set tcp_syncookies to on
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Set tcp_window_scaling to on
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Running script '/etc/firewall.nat6'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Running script '/var/etc/gls2s.include'
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): ! Skipping due to path error: No such file or directory
Tue Dec 31 19:18:45 2024 daemon.notice netifd: ovpnclient (24187): * Running script '/usr/bin/gl_block.sh'
Tue Dec 31 19:18:46 2024 daemon.notice netifd: ovpnclient (24187): * Running script '/etc/firewall.vpn_server_policy.sh'
Tue Dec 31 19:18:46 2024 daemon.notice netifd: ovpnclient (24187): Failed to parse json data: unexpected character
Tue Dec 31 19:18:46 2024 daemon.notice netifd: ovpnclient (24187): uci: Entry not found
Tue Dec 31 19:18:46 2024 daemon.notice netifd: ovpnclient (24187): cat: can't open '/tmp/run/ovpn_resolved_ip': No such file or directory
Unfortunately this isn't the whole log, please post the whole log file.
Wed Jan  1 19:45:31 2025 daemon.notice netifd: ovpnclient (22601):  * Running script '/etc/firewall.vpn_server_policy.sh'
Wed Jan  1 19:45:31 2025 daemon.notice netifd: ovpnclient (22601): Failed to parse json data: unexpected character
Wed Jan  1 19:45:31 2025 daemon.notice netifd: ovpnclient (22601): uci: Entry not found
Wed Jan  1 19:45:31 2025 daemon.notice netifd: ovpnclient (22601): cat: can't open '/tmp/run/ovpn_resolved_ip': No such file or directory
Wed Jan  1 19:45:36 2025 daemon.notice netifd: Interface 'ovpnclient' is now down
Wed Jan  1 19:45:36 2025 daemon.notice netifd: Interface 'ovpnclient' is setting up now
Wed Jan  1 19:45:36 2025 daemon.warn ovpnclient[22946]: DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: library versions: OpenSSL 1.1.1m  14 Dec 2021, LZO 2.10
Wed Jan  1 19:45:36 2025 daemon.warn ovpnclient[22946]: WARNING: --ping should normally be used with --ping-restart or --ping-exit
Wed Jan  1 19:45:36 2025 daemon.warn ovpnclient[22946]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: NOTE: --fast-io is disabled since we are not using UDP
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: TCP/UDP: Preserving recently used remote address: [AF_INET]194.88.99.110:443
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: Socket Buffers: R=[131072->131072] S=[16384->16384]
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: Attempting to establish TCP connection with [AF_INET]194.88.99.110:443 [nonblock]
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: TCP connection established with [AF_INET]194.88.99.110:443
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: TCP_CLIENT link local: (not bound)
Wed Jan  1 19:45:36 2025 daemon.notice ovpnclient[22946]: TCP_CLIENT link remote: [AF_INET]194.88.99.110:443
I hope this shows what you are expecting. when I look at the log it seems to be updating. I have compiled what I can see changing
So far I don't see any issues, I am sorry :confused:
