Gl-a1300
Does GL-A 1300 ROUTER support TorGurd VPN . its not listed under compatible devices!
They seem to support OpenVPN and Wireguard - so yep, should be possible but you need to configure it manually.
You can generate openvpn and wireguard config from their web portal directly and use on the router.
