I’m trying to use the “Extender” network mode to extend the range of some equipment which has a WLAN interface (basically it just broadcasts an Access Point to connect to). There is no DHCP server present in the equipment either.
This works flawlessly with the GL-AR750S.
With the AC-1300, I get the following error after choosing the equipment’s access point:
The LAN subnet conflicts with the Wifi subnet to be connected, please set a different subnet.
I’m a bit confused by this as it was my understanding that DHCP is not involved in “Extender” mode - the radio interfaces are just bridged (as opposed to Repeater mode which uses the firewall/router).
After this error, the GL-AC1300 does not enter “Extender” mode but seems to be in “Repeater” mode:
On a related topic, would be nice to be able to specify an IP Address when choosing WDS Network Mode - I believe this used to be possible? (Internet Settings - GL.iNet Docs)
Can you take some screenshots to see what happens? I did not reproduce on 4.1.2
We failed to reproduce the test here, can you test it with another wifi?
When connecting to the equipment AP, I now get the original error: “The LAN subnet conflicts with the Wifi subnet to be connected, please set a different subnet.”
When you try to reproduce, are you connecting to equipment that simply broadcasts an access point? (with no DHCP server)
Extender is using relay. Thus the router’s own subnet, which is 192.168.8.1/24 by default, should not conflict with the wifi network it is trying to connect.
I can see DETECTOR_AP24 IS USING 192.168.250.2 but I cannot see its netmask.
Also from the video I cannot see the subnet of the A1300 router. Can you show that?
You should also disable your repeater directly, remove save SSIDs in case the router is trying to connect as repeater again.
