I’m having problem with my new router, the modem goes offline when there’s no activity / no wifi client. I have to click auto setup to make it go online again, or power cycle the router.
Do I need to give some commands to the modem to stay always online?
power on router
sim card data established
wireguard vpn established
0 wireless client
after some time (less than 30mins), router appeared offline on goodcloud, so i connected to the wireless and login to control panel, it shows
modem connection still active, however VPN became disconnected (shows ‘ABORT’)
because VPN is disconnected, internet became unavailable
in another scenario where the router has wireless clients connected, then the VPN does not disconnect and internet is available continuously
in the logread file, connection lost at around 16:33 time
So Internet connection is fine but Wireguard dropped for no reason? Is this your server or 3rd-party one?
First you can try to set up vpn policies and let the router itself does not use vpn. In this way, it will not drop from cloud and you can ssh to it from the cloud and do some checking. Maybe restart wiregaurd.
ok, i will try the vpn policy, at least i can reboot the router from goodcloud
