Azndfc
November 3, 2020, 11:39am
Hi all,
I have just tried connecting my new laptop to my GL Inet 150 Router.
I found out that my laptop to GL Inet router is very unstable compared to when connecting via my brother’s wifi at home.
Two things to note are:
When connecting to the home router, my laptop to home router connection is very stable.
When I tried connecting my modem directly to my laptop, the connection never drops.
I had my GL AR-150 Router reset and then set up again.
Why can it possibly happen? It is so weird
Thanks all for your attention to my problem. Peacee
alzhao
November 4, 2020, 8:40am
2
Is AR150 connecting as repeater?
When this happens, can you get the logs? You can go to advanced settings, then status, system log.
Azndfc
November 4, 2020, 3:17pm
3
No, the router is used as a tethering device. A modem is attached to the router. The router is used to spread wifi.
will get to the log. Thankss
Azndfc
November 4, 2020, 3:35pm
4
This is the log attached
SYSTEM LOG.zip (3.7 KB)
alzhao
November 5, 2020, 9:26am
5
From the log it seems caused by ipv6.
Can you disable ipv6 on your pc? Or can you try 3.105 firmware which disabled ipv6 by default.
Azndfc
November 5, 2020, 11:01pm
6
I have disabled ipv6 on my pc. Will report on the result. Thankss
Azndfc
November 5, 2020, 11:02pm
7
Andd… Do you have 3.105 firmware just in case?
Azndfc
November 5, 2020, 11:27pm
8
I have disabled ipv6, but the connection keeps dropping
I have attached the system log again.
Do you know why is this happening? Hehe
SYSTEM LOG 2.zip (5.3 KB)
alzhao
November 6, 2020, 4:57am
9
Can you just try the snapshot here GL.iNet download center
Seems the laoptop disconnect actively and the router didn’t report anything.
Can you change channel and encryption of the router an try?
Azndfc
November 6, 2020, 6:14am
10
Okay. Which one should I choose @alzhao ?
Azndfc
November 6, 2020, 6:26am
11
The link you provide gives the firmware. Should I install it later?
alzhao
November 6, 2020, 8:06am
12
This one GL.iNet download center
I suggest you try to change wifi encryption (WPA WPA2 ) and try
Azndfc
November 7, 2020, 11:19am
13
I have changed my wifi encryption from WPA2PSK to WPA/WPA2PSK but still disconnecting…
SYSTEM LOG 3.zip (623 Bytes)
Azndfc
November 7, 2020, 10:55pm
14
If i change the 3.107 firmware to 3.105 firmware, could it stabilize my connection to the router @alzhao ?
alzhao
November 9, 2020, 10:10am
15
Maybe not. As you said it is new laotop, I assume it should have new wifi chip and should not have capability issues like old wifi chip. Sorry I don’t have a clue.
Azndfc
November 9, 2020, 12:48pm
16
actuallly it is a second laptop… a Thinkpad T460 with Intel Dual Band wireless AC 8260…
Azndfc
November 11, 2020, 2:24pm
17
i think if the problem is rooted in ipv6, i will try disabling by downgrading firmware from 3.017 to 3.015. Is it basicly safe?
alzhao
November 12, 2020, 4:15am
18
The latest snapshot should be 3.105, upgrade, not downgrade
Azndfc
November 12, 2020, 10:45pm
19
This is my current firmware 3.017… Can I drag and drop the 3.015 firmware?
alzhao
November 13, 2020, 4:07am
20
Yes. I think so. Go to “Local Upgrade” and drag and drop the firmware.
