Is it possible to add a 2nd USB port to a GL-AR150 and use two USB devices simultaneously?
Both USB devices are self powered, and do work fine when connected separately to a GL-AR150!
Yes, but you need a USB hub. We tried to drive 10 bitcoin miner before. You can use our Domino board if you want, there is an 3xUSB+Micro SD combo board.
Thank you for the info alzhao.
Will be ordering some more stuff from you guys soon.
Is this the one you are talking about?
How do I connect it to a GL-AR150, and I only see one USB connector?!
It for connect to AR150, only to the domino pi board, which is actually the same hardware as AR150. It had one USB-A, but two other usb as pins on the top
So this will not work for a AR-150 I guess?
Yes. Because physically you cannot connect.
You can find a USB hub, maybe.
