Is it normal for the external antenna mount to be missing the nut? It makes for a very unstable mount of the antenna on my GL-AR150 I just received.
There should be a nut. Can you show a photo?
Oh, ok, I didn’t get a nut, so mine is all loose.
Hi Markus,
Sorry for this. Can you give us your address so that we send you the nut?
