Gl-ar300 antenna
hi i have been searching but always ended with no result.
what kind antenna does ar300 (enterprise edition) use?
is it detachable?
if it doesnot,what is the best gl devices that can use outdoor antenna? i prefer the one that comes with microsd support
thank you
AR300 doesn’t have detachable antenna stick. No SMA style connector.
But it has uFL so you can change the antenna.
But we decided to suspend this model and replace it with a new one.
