As i bought my gl-ar300m no external Antenna Version was available. I ordert two short IPEX 1.0 to Sma cables and 5DBi external Antenna, because i saw connectors on the Board. Can i just plug and Play the cables or is there a need to modify the Board to "Disable"the internal Antenna?
Bumping an old post but I stumble an add for a GL-AR300M, not the -ext version. But it has external antennas, the router looks like on this Aliexpress link
Is that legit? do the antennas actually work while connected like this one a normal AR300M?
Thank you
