Hi, what are the differences between the GL-AR300M / AR300M16 / MT300N-V2 routers?
Which is the fastest to use as OpenVpn client over eth port?
Cheers Raphael
Cheers Raphael
Then click “view all” for further specs.
AR300M and AR300M16 uses the same chipset, I think they have the same speed with OpenVPN, while MT300N-V2 uses MTK chip, it might a bit slow than AR300M or AR300M16.
Thanks a lot kyson-lok
