GL-AR300M connect to lan while on VPN
I have my GL-AR300M set up and connecting to my VPN perfectly.
I use it between my apple TV and my ISP modem to allow me to connect to region locked content.
However, I cannot access my NAS drive while the VPN is active, can you please tell me how I might access it. The GL-AR300M is set to 192.168.8.1, my NAS drive is 192.168.1.121.
I know it’s something to do with the firewall but I can’t for out how to do it.
So when vpn is not active you can access the NAS? If so, you can uncheck the “force vpn” option when starting your vpn and you should be able to access your NAS again.
Check this thread: 404 Page not found - GL.iNet
