I would like to use the GL-AR300M-Ext as a W-Lan repeater. After updating it to the latest firmware 3.024 the router stops scanning for existing wifi-networks at ~25%:
The scan bar runs to about 25% and then abruptly stops. No networks are found anymore.
Thank you.
I tried several times. It is not possible to revert firmware once you updated it. It is only possible to reset to default all other settings, except of firmware…
