Hello, 3 days back upgraded to 3.0.19 firmware. Since then minidlna is not getting enabled. It used to work fine with earlier firmware. Tried disable and enabling from Luci. Tried enable, restart from CLI.
Config file
I tried in AR300M v3.022, didn’t have such problem.
I can try 3.022 if it works.
Pls send me Nand firmware link to upgrade.
Appreciate any advice on fixing the issue…
https://dl.gl-inet.com/firmware/ar300m/
Update didn’t fix. I had to flash with this fiemware to make DLNA work…
Thanks anyways for all your help…
