Nothing you can tell me how to fix it? I invested so much time already…
I think the main problem is that the Modem does not connect to the internet. The Modem LED keeps flashing every 3 seconds.
When i plug in the modem to my computer it connects within 5 seconds. But on the GL it just keeps flashing the modem LED every 3 seconds. Can the Vodafone software on the modem be the problem?
Anything i can do or try?
Do i have to buy LTE modems one by one until finally one works?? That’s not why i bought the GL
This is the Kernel log when i reconnect the modem:
[ 329.228500] usb 1-1: USB disconnect, device number 4
[ 329.233704] cdc_ether 1-1:1.0 eth1: unregister ‘cdc_ether’ usb-101c0000.ehci-1, CDC Ethernet Device
[ 342.247322] usb 1-1: new high-speed USB device number 5 using ehci-platform
[ 342.439708] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 342.457813] scsi host3: usb-storage 1-1:1.0
[ 342.857550] usb 1-1: USB disconnect, device number 5
[ 343.577324] usb 1-1: new high-speed USB device number 6 using ehci-platform
[ 343.914722] cdc_ether 1-1:1.0 eth1: register ‘cdc_ether’ at usb-101c0000.ehci-1, CDC Ethernet Device, 0c:5b:8f:27:9a:64
[ 343.957783] usb-storage 1-1:1.2: USB Mass Storage device detected
[ 343.977570] scsi host4: usb-storage 1-1:1.2
[ 344.983414] scsi 4:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[ 344.999109] sd 4:0:0:0: [sda] Attached SCSI removable disk
I am not sure what is the real problem you are facing.
Why you want to disable modem mode? E3372 just present itself as a ttyUSB device and you can just leave that unattended. It will NOT connect and it will not bother you.
It works in Tethering mode now and that is how it works.
The USB dongle is working in TETHERing mode and it will not work in Modem mode at the same time.
That’s why i thought i need to disable the Modem mode. I never had a connection with a Modem working. So i was just not sure how it should be/look like…
So the problem i am facing is more clear to me now: The E3372 won’t connect to a 4G or 3G network. The LED on the E3372 keeps flashing.
When i connect the E3372 on a Windows machine. It connects within 5 seconds.
Yes.
You Huawei E3372 is connected to GL router
Huawei Ee3372 is working and its IP 192.168.9.1
It is correct that 192.168.9.1 pop up because you need to click that “connect” button in order to use the Internet.
After you connect E3372 to Carrier, then everything is good.
I didn’t see anything wrong. Just omit the modem info as Huawei E3372 presented itself as modem and tethering devices. But it actually work in tethering.
No VPN. To make it work i kept the router as “clean” as possible after every fresh reset.
I just looked into that link you mentioned… That’s over my head. I can’t really understand what they are doing even-though i do a bit of Linux
So before i spend a week of frustration. I am gonna buy another modem.
Suggestion which model works 100% ?
(Since i am in Sumatra for the next months it must be available here: tokopedia.com)
Thank you for your time though and patience with my lack of knowledge.
