I’m having issues connecting to an OpenVPN server with the AR300M. Basically it connects but I cannot load certain websites (ie: all websites on google servers load but websites outside of that probably won’t load).
I know the VPN is working because i downloaded the open vpn client to my pc and it loads all the websites just fine. It’s just not working through the router.
I also have a NordVPN subscription and it does work perfectly on the router. So i cannot understand why i can’t get this openvpn that I have setup to work here.
The AR300M has correctly sent the packets to the VPN server.
Please check the list of VPN clients on the VPN page of ASUS.
If the AR300M is visible, a VPN tunnel has been established. You should check the configuration and VPN logs on your ASUS router to resolve the issue of the VPN server not forwarding packets from the AR300M to the Internet.
Otherwise, the VPN tunnel has not been established. Please check the AR300M logs.
I was facing a similar problem. I have my own OpenVPN server on an Asus RT-AC66UB1. The server was set and configured using the Asus built in tool. The OpenVPN client file was installed in the AR300M. During quite some time I could connect to the VPN server without any problem and to surf through the web flawlessly, but since some time ago I was facing problems to access most of the websites and servers, but the connection to my OpenVPN server has been always established. While reading your posts I managed to understand that the problem might be coming from a DNS resolving issue, therefore I made this setting:
By doing this, my problems disappeared. This applies to the AR300M with 3.215 firmware as well as for the Mudi E750 with 3.215 firmware.
I hope this helps.
I did what Bpz1970 suggested but altho it mitigates the problem, I still cant access some websites and services I need, specially microsoft Teams.
On a side note if I connect my phone to a regular router, and then run the OpenVPN app on it to the same VPNServer, everything, inlcuding Teams work, so its not the server problem.
