I received my GL-AR300M and so far everything is working great! I plan on using this as a transparent OpenVPN client (connecting to my router at home) for holidays and during my commute. I do have a couple of questions though.
How do I set the purpose of the middle LED, I want to be able to see if the VPN is up but can’t seem to get it working (looked in advanced settings under LED but a bit baffled what to set it to)
As OpenWRT has apparently been superceded by LEDE; when can we expect an LEDE 17 build in stead of the current (2.26) OpenWRT 15.05 version?
I am already running 2.26 so does that mean the middle LED is broken?
I didn’t realise LEDE and OpenWrt were re-merging, looking forward to the update. (even though the current version seems to be running great!)
I updated the first post, so the link should work! (Note that 2.4.0 is 3 versions behind the current one so I’d guess there are a couple of more vulnarabilites in the current build)
config led ‘led_wlan’
option name ‘WLAN’
option sysfs ‘gl-ar300m:wlan’
option trigger ‘phy0tpt’
config led ‘vpn’
option default ‘0’
option name ‘vpn’
option trigger ‘netdev’
option dev ‘tun0’
option mode ‘link tx rx’
root@GL-AR300M:~# less /etc/config/startvpn
less: can’t open ‘/etc/config/startvpn’: No such file or directory
