Hi!
I have a GL-AR300M (firmware version 3.019) and I need to use it as a VPN server without a public IP address or behind firewalled connection.
I installed Softether VPN server because of vpnazure, it performs exactly what I need!
I can reach the router from VPN client but I can’t ping any davice connected to its LAN, even if I configured a bridge between my virtual HUB and lan1 interface.
I can ping connected devices from Network Diagnostic tool provided in Luci interface.
I attach the server configuration:
declare root
uint ConfigRevision 17
bool IPsecMessageDisplayed false
string Region US
declare DDnsClient
bool Disabled false
byte Key O5V0F4NH1TX0Wx8NGX+WfCMuo78=
string LocalHostname GL-AR300M
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare IPsec
bool EtherIP_IPsec true
string IPsec_Secret ******
string L2TP_DefaultHub DT-HUB
bool L2TP_IPsec true
bool L2TP_Raw false
declare EtherIP_IDSettingsList
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
bool DoNotDisableOffloading false
declare LocalBridge0
string DeviceName eth1
string HubName DT-HUB
bool LimitBroadcast false
bool MonitorMode false
bool NoPromiscuousMode false
bool TapMode false
declare ServerConfiguration
bool AcceptOnlyTls true
uint64 AutoDeleteCheckDiskFreeSpaceMin 104857600
uint AutoDeleteCheckIntervalSecs 300
uint AutoSaveConfigSpan 300
bool BackupConfigOnlyWhenModified true
string CipherName RC4-MD5
uint CurrentBuild 9656
bool DisableCoreDumpOnUnix false
bool DisableDeadLockCheck false
bool DisableDosProction false
bool DisableGetHostNameWhenAcceptTcp false
bool DisableIntelAesAcceleration false
bool DisableIPv6Listener false
bool DisableNatTraversal false
bool DisableOpenVPNServer false
bool DisableSessionReconnect false
bool DisableSSTPServer false
bool DontBackupConfig false
bool EnableVpnAzure true
bool EnableVpnOverDns false
bool EnableVpnOverIcmp false
byte HashedPassword sLn40ZTrPMLUZ8coPzq0XOXYjUw=
string KeepConnectHost keepalive.softether.org
uint KeepConnectInterval 50
uint KeepConnectPort 80
uint KeepConnectProtocol 1
uint64 LoggerMaxLogSize 1073741823
uint MaxConcurrentDnsClientThreads 64
uint MaxConnectionsPerIP 256
uint MaxUnestablishedConnections 1000
bool NoHighPriorityProcess false
bool NoLinuxArpFilter false
bool NoSendSignature false
string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
string OpenVPN_UdpPortList 1194
bool SaveDebugLog false
byte ServerCert ****************
byte ServerKey ****************
uint ServerLogSwitchType 4
uint ServerType 0
bool StrictSyslogDatetimeFormat false
bool Tls_Disable1_0 false
bool Tls_Disable1_1 false
bool Tls_Disable1_2 false
bool UseKeepConnect true
bool UseWebTimePage false
bool UseWebUI false
declare GlobalParams
uint FIFO_BUDGET 1000000
uint HUB_ARP_SEND_INTERVAL 5000
uint IP_TABLE_EXPIRE_TIME 60000
uint IP_TABLE_EXPIRE_TIME_DHCP 300000
uint MAC_TABLE_EXPIRE_TIME 600000
uint MAX_BUFFERING_PACKET_SIZE 480000
uint MAX_HUB_LINKS 1024
uint MAX_IP_TABLES 65536
uint MAX_MAC_TABLES 65536
uint MAX_SEND_SOCKET_QUEUE_NUM 128
uint MAX_SEND_SOCKET_QUEUE_SIZE 320000
uint MAX_STORED_QUEUE_NUM 384
uint MEM_FIFO_REALLOC_MEM_SIZE 65536
uint MIN_SEND_SOCKET_QUEUE_SIZE 80000
uint QUEUE_BUDGET 1024
uint SELECT_TIME 256
uint SELECT_TIME_FOR_NAT 30
uint STORM_CHECK_SPAN 500
uint STORM_DISCARD_VALUE_END 1024
uint STORM_DISCARD_VALUE_START 3
declare ServerTraffic
declare RecvTraffic
uint64 BroadcastBytes 837443
uint64 BroadcastCount 6726
uint64 UnicastBytes 798817601
uint64 UnicastCount 714305
declare SendTraffic
uint64 BroadcastBytes 1497208
uint64 BroadcastCount 11365
uint64 UnicastBytes 19074389
uint64 UnicastCount 51774
declare SyslogSettings
string HostName $
uint Port 0
uint SaveType 0
declare VirtualHUB
declare DEFAULT
uint64 CreatedTime 1553252757426
byte HashedPassword +WzqGYrR3VYXrAhKPZLGEHcIwO8=
uint64 LastCommTime 1553252757419
uint64 LastLoginTime 1553252757419
uint NumLogin 0
bool Online true
bool RadiusConvertAllMsChapv2AuthRequestToEap false
string RadiusRealm $
uint RadiusRetryInterval 0
uint RadiusServerPort 1812
string RadiusSuffixFilter $
bool RadiusUsePeapInsteadOfEap false
byte SecurePassword bpw3X/O5E8a6G6ccnl4uXmDtkwI=
uint Type 0
declare AccessList
declare AdminOption
uint allow_hub_admin_change_option 0
uint deny_bridge 0
uint deny_change_user_password 0
uint deny_empty_password 0
uint deny_hub_admin_change_ext_option 0
uint deny_qos 0
uint deny_routing 0
uint max_accesslists 0
uint max_bitrates_download 0
uint max_bitrates_upload 0
uint max_groups 0
uint max_multilogins_per_user 0
uint max_sessions 0
uint max_sessions_bridge 0
uint max_sessions_client 0
uint max_sessions_client_bridge_apply 0
uint max_users 0
uint no_access_list_include_file 0
uint no_cascade 0
uint no_change_access_control_list 0
uint no_change_access_list 0
uint no_change_admin_password 0
uint no_change_cert_list 0
uint no_change_crl_list 0
uint no_change_groups 0
uint no_change_log_config 0
uint no_change_log_switch_type 0
uint no_change_msg 0
uint no_change_users 0
uint no_delay_jitter_packet_loss 0
uint no_delete_iptable 0
uint no_delete_mactable 0
uint no_disconnect_session 0
uint no_enum_session 0
uint no_offline 0
uint no_online 0
uint no_query_session 0
uint no_read_log_file 0
uint no_securenat 0
uint no_securenat_enabledhcp 0
uint no_securenat_enablenat 0
declare CascadeList
declare LogSetting
uint PacketLogSwitchType 4
uint PACKET_LOG_ARP 0
uint PACKET_LOG_DHCP 1
uint PACKET_LOG_ETHERNET 0
uint PACKET_LOG_ICMP 0
uint PACKET_LOG_IP 0
uint PACKET_LOG_TCP 0
uint PACKET_LOG_TCP_CONN 1
uint PACKET_LOG_UDP 0
bool SavePacketLog true
bool SaveSecurityLog true
uint SecurityLogSwitchType 4
declare Message
