Hi @alzhao ,
I have tried now again and still have issues.
I will post here the response I gave to the support gentleman just to keep things alligned and I am sorry I give you such a headache
"I have tried your instructions and something is still not working well.
Let me please explain :
Try 1:
- My Nor flash IC is Winbond W25Q128 and has GL.inet firmware 2.20 on it
- I power the router connected to serial and flash the ART .bin file but for me there is no NAND memory (my router did not come with one) so I get a different message in the console. Please see the attached image glfw2_flash art ok.png
- After this I try to upgrade flash from firmware update on 192.168.1.1 with a NOR image for software version 3.104 . The image uploads but the router never restarts ( i waited 30 minutes) .
- If I disconnect the power form the router and connect again, the router is still not powering up .
Try2 :
- I bought a new flash IC , also Winbond
- I have flashed on it GL.inet firmware 2.20
- Upgrade the router to 3.104 from the router UI at 192.168.8.1 → all working perfect after the upgrade but not the correct MAC address as I didn’t flash the ART .bin yet
- I power the router connected to serial and flash the ART .bin file but for me there is no NAND memory (my router did not come with one) so I get a different message in the console. Please see the attached image glfw3_diff1_no_nand.PNG and glfw3_diff2_atr flashed ok.PNG
- Now I can not power the router at all, meaning I can not get anything on serial and I can not get to uboot by pressing the reset button and then apply power and wait for the led to flash 5 times.
I will take the NOR memory from the pcb and flash on it again the GL.Inet 2.20 firmware as that is the only one I have a full NOR IC backup for. "
I have just blanked the ART .bin filename on the forum while the support has the clean screenshot.
L.E.: I have just tested all the options above plus I tried flashing the ART .bin from 192.168.1.1/art.html on a MX25L12835F memory IC but the results are identical to the Winbond memory IC. It has to be me doing something wrong but I surely can’t figure what I am doing wrong ![]()
