GL-AR300M Wifi Goes On and Off
I am experiencing an issue with my GL-AR300M. I use it in WISP mode, it connects to a wifi signal and creates a new wifi network that I connect to. The problem I am experiencing is that the wifi signal starts to go on and off intermittently, I have to disconnect the power and switch it back on to get it to operate normally again. Has anyone experienced this? What could be the problem?
Thanks,
The power supply.
Maybe the power adapter or the WISP connection.
Is the WISP signal good?
I started having the same issue after moving from one place to another (I am a full time RV’er). Not really sure why, but at the time I was using a VPN on my Tethered iPhone and a VPN on my Computer (i.e. VPN on both sides of the router). When I turned off the VPN at the Computer and left the VPN on the iPhone, that fixed it. I have also started a new way of dealing with the problem: I do a “backup” (under “systems” in Luci) of the firmware when it is working good and name it after the place/date of backup. Then, each time I find a problem at a place I am new to, I do a factory reset and start fresh - then do another backup (when all is working well) named after the place/date of the new location. Over time, I find that when I return to a place I have been before, I simply reinstall from the backup of that location - saves time and works great.
