What is the typical wireless range / coverage of the AR300M?
Hi gjames92,
That is a very difficult question to answer accurately. The AR-300m seems to have PCB mounted antennas which are perhaps not as good as external antennas. However, it should cover most of the
house/flat/apartment that you are in. It may not cover all of it though. Typically, it should pass relatively easily through one wall, and with a reduced signal, two walls. Problems begin when you get to two walls and a floor. I run two routers in my house, one on either side of the staircase for this reason. You should get a good signal if you can see the router. I hope this helps.
Tony
