I have blackvpn. They give instructions for configuration with OpenWRT here. Which (if any) of these setup instructions should I follow? (New at this).
https://www.blackvpn.com/support/openwrt-15-05-1-with-openvpn/
TIA!
TIA!
Just download the configure files from your link and upload to the router via the UI.
Omit all the other instructions.
I don’t see any .opvpn fies listed on that page? Is that what I’m looking for? They list the following .opvpn file on another page, but it is for Android. Should it work just the same? Does it look like this will work even though they list it for Android?
auth-user-pass
remote australia.vpn.blackvpn.com 443 udp
client
dev tun
fast-io
persist-key
persist-tun
nobind
pull
comp-lzo
tls-client
key-method 2
ns-cert-type server
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>
key-direction 1
<tls-auth>
-----BEGIN OpenVPN Static key V1-----
b790ea189139a6482df3c54dc1996921
8627b6df4d936641ad96e4a3f34e4cfb
5930684c142c0f3485c7b2633a34165d
d67d005b7148c6b26aea1e6322696e96
d81e9e6fa4b4c9bc394870e2986c59e3
6a21b700fe829d3cd01ca35d94538d5f
7194a27fac3c90f6be605e223a37fbd2
1ef499acd3aeccb79661f6f7029880d1
924b356f68cb1c7f174b55812684037d
886bb8cd81c0e524155148a10eba62e7
065b96328e977db0f5e92f27e19f6f3f
5c9480f2fff0870b4fb902d7fed50c35
7ebc4777fc57ffbca0448d2e2165af71
7182e050804283acb82350d82d0230da
ece1fc4be9eea7bdba08e24e8fa3f1d0
7b39bc883519ff38eaf4514859b824f2
-----END OpenVPN Static key V1-----
</tls-auth>
cipher AES-256-CBC
auth SHA512
verb 3
mute 10
Just grab the zip file and drop it in the GL web interface.
Glitch
find this line: Download our zip file with configs and certificates
There is a zip to download
For future users, method for blackvpn on openvpn is here:
Thanks.
